![]() | Home > Maintenance & Mods (L322) > Replacing Sensors still! |
Nope, u cant |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
you're probably right dan, i switch mine off when manoeuvring but i'm not 100% whether the backs are still on or off..my 05 was the cross from bmw to ford so they probably put all these options on to sell old stock. ... - .- -.
I had the bumper off today in the hopes of finding some chaffed wiring. No such luck, so have to go for ECU next I suppose.
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
Yep it's software option. All off, front off rear on & both on arethe options. This can be done by an indy with the AutoLogic kit so you can save on the labour. The headlamp delay shouldn't had messed up the sensors as that is contain within the body control module and is separate to the pdc module. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior |
Unless they didnt know what the they were doing? ![]() |
JIMMYM Member Since: 06 May 2010 Location: Saddleworth Posts: 29 ![]() ![]() |
A quick query in relation to PDCs. A colleague at work has scuffed the corner of my TD6 front bumper pulling out of his parking space in his car. Have taken it to a LR approved bodyshop for an estimate and they reckon that the bumper needs removing and stripping to repaint properly and also that the PDC sensors will require reconfiguring on diagnostic software when refitted. Does anyone know if the sensors will require reconfiguring if unplugged from front bumper? Only reason is that the guy wants to pay for the repair himself, which would also suit me better as I won't have to declare a non fault on any insurance application and the quote I've received is quite expensive. If PDC sensors don't require reset then I can maybe shop around for a cheaper quote from a good bodyshop but without Autologic or similar.
I am no mechanic but would have thought that if the car was fully "Asleep" or Battery properly disconnected then the car will "Never Know" that the sensors have been disconnected and then reconnected as they were previously.
+1 ..what gary says... ... - .- -.
There is no "configuring" to do with the PDC system at all. You can swap sensors round till your hearts content. With the system active or not. It's a relatively basic system.
Cheers fellas - pretty much what I assumed especially if battery disconnected. Think LR bodyshop trying to talk job up. |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Stvegt-" The pdc ecu is the same for all 02-09MY cars. There are some older modules out there but basically the module is the same just made by a different manufacturer."
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
http://www.brit-car.co.uk/product.php?xProd=138652 2002 td6 vogue, 06 supercharged facelift
Thats the part ive found but at £35 new. will it fit a 2002? As my unit ends in 930. Whats the difference? |
it says that 930 is no longer supplied and has been superceded with 931 , dosent say what the difference is but according to brit car it should work fine 2002 td6 vogue, 06 supercharged facelift
