Home > General > Scared the living daylights out of myself last night...
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
My 02 Vogue has an intermittent "Engine Failsafe" message coming up when I hit a bump (of which there are plenty in this area Crying or Very sad ) so I've been trying to track the reason down. Had a false alarm a couple of weeks ago with a hose off the EGR which made the problem much more common but hit a bump after I fixed the EGR hose and the old issue is still there...
Anyway, I've got a Faultmate which is excellent but I've had it a while and had to return it for repair - It came back on Thursday so I went out last night and I'm not really sure what sequence I plugged it all together but the RR went MENTAL!!! Shocked The bloody siren inside / outside is enough to cave your ear drums in so I was really popular and couldn't get it to stop - it went through three cycles, the air suspension went inactive, the key fob wouldn't work, the boot wouldn't open.. no interior lights. It wouldn't communicate with the Faultate either so I was ready to jump off the roof of the house. Big Cry
Did a bit of soul and web searching and ventured back out this morning to see if it had maybe gone into "Major huff mode" and come out of it through the night. Unfortunately not.
However, starting from basics, I checked the fuses and found a blown fuse to the diagnostic plug and once that was replaced, a whole bunch of dead stuff woke up, and I could interogate via Faultmate.
30mins later, all faults cleared. Voila! However, I'm sure I've got a bunch more grey hair than I had yesterday!!
DC
Post #34518 31st Oct 2010 9:42pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Duff battery Question
Post #34519 31st Oct 2010 9:57pm
dan_uk_1984
Loose battery terminal?
Post #34520 31st Oct 2010 10:02pm
mzplcg
LOL, I have felt that pain too, e.g. the siren bit. Mine took a full 30 seconds from when I opened the bonnet to go off so I was right in the firing line so to speak.
As our German friends might say, Die fukken niir schitten selfen.
Mine turned out to be a weak battery which was causing all sorts of mysterious bongs, warning lights, error messages and the odd blown fuse.
Post #34527 1st Nov 2010 7:06am
DeltaC
Thanks.
I must confess to not having thought of a loose battery connection but the battery itself is only a year old and seems to be performing fine in all other respects.
I'll check terminals, earth points etc tonight.
Post #34549 1st Nov 2010 1:00pm
