Home > Maintenance & Mods (L322) > Rear squeak
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Rear squeak
Evening
Last week it went in to an Indy for a rear drivers side squeak. It squeaks like a pram when going over speed humps.
After a few hours the y rang to say all the bushes seem fine apart from slight play in upper hub bush.
I said change upper and lower hub bushes on both sides.
Picked it up and drove home £400 lighter to find the squeak still there, no improvement.
Took the car back the next morning.
They disconnected the right hand shock and rocked the car to eliminate it and the squeak was still there.
They rang to say the camber bolt on the stabilising arm is siezed and rubbing on the inside metal.
New arm and bolt, another bill and problem solved!
Ok for 24hours and yes you guessed it, the same squeak has returned!
The car is going back in tomorrow for another investigation.
Any ideas?
Post #313314 17th Feb 2015 7:44pm
pld118
Paul,
Have you searched other threads. Type pram into the search engine or squeaking if not done.
Here's one
http://www.fullfatrr.com/forum/topic12129.html?highlight=pram
I was advised to progressively spray WD40 or silicone lubricant onto the possible part, one at a time, to try and pinpoint/ rule other parts out as opposed to throwing money at it.
Post #313349 17th Feb 2015 11:54pm
mjdronfield
Mine does this from time to time.
I generally cure it by driving diagonally on to the grass bank outside my Dads house. Gives it some axle articulation. Fine for 6 months or so after....
Try that, I can pm you my dads address and he makes a good cuppa Rolling with laughter
Seriously though, get it twisting about and see if it settles.
Not the root cause I know..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #313372 18th Feb 2015 6:28am
PaulB
Thanks chaps.
I've spent hours searching the whole internet looking for popular causes.
I took it back in today and they rang to say the aftermarket stabilising link arm they fitted on Friday seems to be noisy.
They have fitted a replacement and all is quiet, for how long is anyone's guess.
Post #313500 18th Feb 2015 6:39pm
Knew if I waited long enough for the rains to come my LHR squeak would go away. It has Thumbs Up .
Post #345346 31st Aug 2015 5:58pm
Madyaker
United Kingdom 2002 Range Rover Vogue 4.4 V8 Barolo Black
I had all the rear bushes replaced to solve this problem. It worked for going over bumps and potholes but I'm currently saving to sort out another squeak on the rear bearings ! Shocked
Post #345372 31st Aug 2015 8:05pm
Rear rose bushes were the cause of my rear end squeak, new bushes and it's never squeaked since Thumbs Up
Post #345382 31st Aug 2015 8:57pm
drive2tractors
I had an annoying squeak too, (2003 4.4V8), tracked it down eventually to the handbrake cable rubbing through the rubber grommet in the retaining loop bolted to the wishbone. The cable was worn through to the metal sleeve. I rotated the grommet 180 degrees and then slipped some hard plastic tubing over the worn cable. I used 10mm ID air line as hard tubing, 10 cm length split lengthways. I held all in place with a small cable tie butted up to the pipe each end.
All quiet now and a nice inventive fix if I say so myself. Certainly cheaper than new handbrake cables!
d2t
Post #346266 5th Sep 2015 9:10pm
Ianmaney
United Kingdom 2011 Range Rover Vogue SE TDV8 Mariana Black
Mine sounded like an old pram up until last Tuesday, had both top hub bushes changed, silence ever since, £160 all in Thumbs Up Semper in merda sumus, solum altum variat !!
Current: 2011 4.4 TDV8 Vogue SE
Last one: 2003 3.0 TD6 Vogue
Post #346418 6th Sep 2015 7:59pm
