![]() | Home > General > My first collision |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
I rather suspect the main difference is that one driver is French and the other isn't |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
thank you for the explanation John.. |
| SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459
Yes the UAE logic was fantastic ...it was your fault because if you weren't in our country the accident would not have happened.
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
same rules apply here indeed. did you takes pictures of the 2 vehicles on location? For others : unless you are 200% sure not to be at fault (say you are hit from behind) do NEVER fill in a constat amiable in the rush of the accident as if you mess up a minute detail, it can do it be turned against you : simply give your details to the other party and take his/hers. Then, once home, send you version of the events, you may use a constat amiable form or simply write a lettre. if possible, take pictures of the events too. Constat amiable has no official value, it just help insurances gather your and their info ( a find a way to the the other party to pay) Ask us how we know... l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 Last edited by verydisco on 31st Aug 2015 9:32pm. Edited 1 time in total |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
'Facts' not in dispute - so it's over to the insurance companies to slug it out
Good pics, now the fact it is a private car parc will most likely mean 50-50 (this is how insurance deal with is unless you are static), to be honest this may help you as - you may/may not know - in France, traffic incoming from the right has right of way ("prioritée à droite"). So, you should have given him way since there are no Stop or Give way sign on the ground or posted.
Thanks |
Of course. again, any question, PM me, I am not that far btw l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
| HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169
i carry one in my car to use in this country its easier than scraps of paper if you should have a little prang |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277
The only thing I would add to what is already said is that, once signed, it is cast in stone and is pretty impossible to introduce anything that differs. So be sure that what it says is accurate from your point of view. John
| Chaffers Member Since: 04 Feb 2015 Location: South Bucks Posts: 14
Sorry to hear - I share your pain! Speaking from recent experience, the oil may well be from one of the intercoolers, which are located just behind the front bumper on each corner. If so, can I suggest that you remind them to check all the pipes, only it's turned out that mine has a leak that wasn't picked up until the engine started going into restricted performance when the turbos spin-up, over 2000rpm and then there is a pressure differential between the 2 of them and that's what trips the sensor. |
Thanks - that sounds like it - it's a radiator right in front of the wheel & behind the bumper - hard to see from the outside as it's boxed in - I think wheel off & remove wheel arch liner is the only way to access it, but it does look bent from what I can see.
Here's my problem - nicely dented intercooler (I think) -
| All times are GMT |
