![]() | Home > Maintenance & Mods (L322) > L322 Which side steps? |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
When you say "the ones with the silver strip" i imagine you mean the ones with the built in mud flap at the front?
| rumble Member Since: 28 Aug 2015 Location: West Sussex Posts: 14
It's hard to know which are the OEM ones as there are so many versions out there!
They're the pattern (Britpart) version of the OE ones. The plastic will likely only be painted black, the same as when they are painted silver. So whether you paint them or someone else does there is still a risk of them getting scratched. They're only likely to get scratched (or broken) from underneath, ie if you ground them on something.
Aha makes sense, thanks.
| All times are GMT |
