Home > Technical (L322) > Small Pipe Right Hand Side of the Engine Block
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Morning. I was doing some poking around in the engine bay last night and found a small almost hook shaped plastic pipe sticking out from the cover of the engine on the right hand side. The other end appeared to vanish down to the underneath of the Block.
Anyone know what it is?
Also, still going on about my TV issue. Could it be battery related? does the TV need more oomph than the DAB etc??
Thanks again.
Post #345606 2nd Sep 2015 8:10am
johnboyairey
i'm not familiar with your model, but range rovers have some breather pipes fitted, to the axles and i think gearbox, and starter motor, they are black or white, and made of stiff nylon, and have a rounded end around 2 inches? to allow air to exit or enter when said items warm up, but (hopefully) not let in water when wading etc. Hence they hieght, and safe position,at rear etc.
Post #345608 2nd Sep 2015 8:17am
Mcnallykev
Ace thanks! I didn't look like it should be connected to anything but thought I better check!
Post #345616 2nd Sep 2015 8:41am
Zirconblue
No they just vent to the air. On the Range Rover's they're raised right up, so that if you go and drive through a flood (wading) the water doesn't get into them.
Post #345618 2nd Sep 2015 8:57am
lee37Vernon
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Sounds line the transfer box vent, mine wee'd a bit after playing up the woods! Had to follow it back down to see where it went, I extended mine upwards a tad so it drops back into box rather than drips on my rocker cover.. 2003 4.4 Adriatic Blue FF
Post #346037 4th Sep 2015 10:18am
