![]() | Home > In Car Electronics (L322) > cd changer and most problems, help needed |
| clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183
after checking all fuses with no battery connection
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
a battery re-connect reboots the ecu's and helps to solve some problems...have you any water ingress in the rear near side cubby hole.. ... - .- -.
no, i checked that before anything.
| Matricks Member Since: 19 Jun 2015 Location: Wilts Posts: 17
clemenz,
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
Mine didn't appear to need a code when i replaced the battery. I suspect they're vin coded to the vehicle like Peugeot/Citroen's.
i did only disconnect the negative lead.
Thanks gents.
| All times are GMT |
