My MOST system has been invaded by gremlins
I've posted on other threads about the cause - the damn Bluetooth module.
Since the Bluetooth module packed in I've bodged a bypass and brought a bypass plug off ebay (waste of £35) - the Bic worked just as well.
Battery has been disconnected and reconnected - made no difference to the problem
I'm at the stage now where the system will boot up and turn off without hanging on the LR badge - but I cant select the TV or CD. The radio works fine - apart from the volume knob?
I've been through the diag mode which recognises that a device is missing from the MOST loop, shows the TV static when checking the video inputs and when testing the hard keys the volume knob works. All connections to the various devices seem tight and solid. I've left the BT module unplugged.
I'm wondering if the pin out cable for the BT module can be jumped?
But cant work out why having a device 'missing' would affect the CD/TV?
I've downloaded the fuse diagram from xtremelandy - though these don't seem to match my 2005 MY L322.
I've pulled every obvious relevant fuse in the in car diagram but no joy and am content that the CD player works - when the fuse is pulled and re-inserted I can hear it cycling through the CDs.
Any ideas anyone
Thanks
