![]() | Home > In Car Electronics (L322) > Dashcams |
| Ethanicus Member Since: 23 Feb 2015 Location: Surrey Posts: 34
After lots of research and testing with friends unit I settled on the Blackvue DR650GW. Inc front and rear camera and built in wifi. Plus the apps are very good too. It had a bit of an issue with high contrast but latest firmware has fixed this. I run 1080p front and 720p rear and you can pick out numbers plates fine. Best thing it has stealth mode so the dealer thinks it's off and they can lie through there teeth. If you pm you email I'll send you some test footage. To use parking mode properly I also added the power pack, this turns the camera off when the voltage drops. Also budget for a class 10 branded 64gb card do you can fit and forget. 2010 - Range Rover VSE 3.6 TDV8
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
There are some slightly older threads in this ever changing market re dash cams. I was watching recently on YouTube, a reviewer named 'tech moan' he does lots of dash cam reviews. But as I say the market is changing all the time. |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
have a look at these fella |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
I've had an Eprance for nearly 2 years now. It was only about £50 but works perfectly, it's not just really good for £50 it's really good full stop - day or night. |
| Blade74 Member Since: 01 May 2015 Location: Sydney Posts: 55
I fitted a Blackvue DR650 dual channel a few weeks ago and have been very happy so far. |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
I got a transcend cam a few weeks back off of Amazon, clicks on each time you turn the car on. The footage seems pretty reasonable and it was only about £50 ish. Whether you could capture number plates I don't know, I haven't put the sd card in the PC yet.... There is nothing that can't be fixed with a hammer😜😜
