![]() | Home > Technical (L322) > Aargh!! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
I would use some absorbent paper like kitchen roll & wrap it around whatever you can - that should help narrow down where it's coming from |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
UV dye kits aren't expensive.
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
it seems to be quite a bit - about 500ml on 750kms and then another 100ml or so within the last 60kms.
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 ![]() ![]() ![]() |
I had a loss of coolant that was rather random. Was a small prick in corner of rad, could only see it when I did gearbox service, worth a look, aux pump shouldn't stop water flowing through it if duff, just won't pump it.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
Just pop down your local garage and ask them to pressure test it, they just pump air into the system to raise the pressure, simulates driving at speed whilst stationary, should show up where there is a leak... Pete
