![]() | Home > Technical (L322) > [URGENT] Removing the front knuckle |
| birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147
Still needs supporting as the pressure in the air bag will drive it down to the limit of the damper |
| alx Member Since: 13 Jul 2014 Location: Beds Posts: 99
Perfect! Many thanks birchyman71. |
Good luck with it they can be an absolute b@&t@£d |
Didn't need to take the steering knuckle off in the end. Got the ball joint out in situ. After replacing it the clanking hollow noise is still there. I've only done one side though but you can hear the noise coming from the driver side (as well as from passenger's but that's for next week).
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
exactly when does it make this noise?? Pete
When rolling over bumps and humps. |
There are two lower ball joints, no upper ones. Have you checked both?? the drop links can give noise especially if the hardened washer under the top nut has been left off... |
You are indeed correct, both are lower joints sitting next to each other. However I don't believe I've seen a washer, only flanged nuts. Is there supposed to be one or two - one for each link?
OK, so just to finish this one off. The noise was getting worse so I've ordered 4 new Lemforder anti-roll bar linkages from CP4Less (front and rear - £80 with the discount delivered) and yes, indeed, the front top joint had a washer which I reused. Didn't do the rear yet but the front is nice and quiet again. Nice! |
Top job, sorted... |
Thank you Haylands, I'll keep that in mind
Dan at Duckworths Land Rover Main Dealer, site sponsor on here, he gives trade prices and free P+P on most things... very good service from him, he also stocks OEM parts so you get the proper quality without the silly main dealer prices... |
Thanks Haylands. Will keep Dan in mind next time I need OE parts.
| steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356
I would put money on the drop link |
