![]() | Home > Technical (L322) > My exhaust has thrown up |
The fiberglass threads from my exhaust have started coming out of the off side pipe , is this bad ?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35821 ![]() ![]() |
are you sure that nobody has put something up the pipe as a joke.. ... - .- -.
I have thought that but it is fiberglass , it's black from the exhaust yet it has just appeared and they use fiberglass in the final muffler , or at least I think they do . 2008 MY Supercharged
Oh well after two Range Rovers and eight years something has finally broken , and now for Land Rover Australia's 400% mark up |
Go for a decent custom one as it will be much cheaper and should last longer and probably save some weight over the massive standard item! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Custom made (lighter) ones will probably be louder - might get boring on a long trip. All that wadding is what adds the weight.
I have now found where it's coming from , the perforated metal inside the end pipe under the stainless steel finisher corroded away at the bottom presumably where water might sit and the fiberglass is from the sandwedge of the two layers . Hopefully I can just get the final bit of pipe .
