Home > Technical (L322) > webasto heater
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
webasto heater
Hi any advice on how to remove & refit webasto heater to my 2006 r/rover . have acquired a 2nd hand unit & want to fit it myself but any heads up advice greatfully received thanks Bow down
Post #346366 6th Sep 2015 1:57pm
Zirconblue
So i assume yours is broken and you're replacing it with a second hand unit?
I've not taken mine out but i did have a look when i changed the battery the other day and with the battery tray and wheel arch liner removed it looks pretty good for access
If you're replacing an existing one, then it should be fairly easy as all the electrical and plumbing connections will be there.
Post #346375 6th Sep 2015 4:48pm
Through the wheel arch..... I reckon.
Clamp the feeds off from the cooling system and fuel, then it should just unbolt. There is nothing that can't be fixed with a hammer😜😜
Post #346379 6th Sep 2015 5:03pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
as above
wheel off, plastic wheel arch cover off, but no need to clamp fuel line
they are not self priming so a bit of a pain to bleed the cooling system
Post #346419 6th Sep 2015 8:00pm
Good point you shouldn't have to clamp the fuel, I do recal that they are a pain to bleed, I took the feeds of mine to check the impeller was still working, and it took ages to get the air out. There is nothing that can't be fixed with a hammer😜😜
Post #346423 6th Sep 2015 8:28pm
