![]() | Home > Technical (L322) > TD6 Gearboxes and towing |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Depends on the deal you can get if the car has had the gearbox replaced or not.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1040 ![]() ![]() |
The main failure mode of the 5L40-E transmission in the TD6 is through reduced hydraulic pressures caused by wear in the valve bodies from spool oscillation in the soft aluminium blocks.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
I have towed an Ifor with 2 17.2 warmbloods pretty much every couple of weeks for the last 9 years all over the UK. To be honest it is all that it does.
reb78 Member Since: 06 Sep 2015 Location: Herts Posts: 55 ![]() ![]() |
Thanks. This is really helpful.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
RRphil real good explanation, my car was chipped on the basis it would prolong the life of the gearbox but 60k later and looks like being changed again and I don't tow only very small trailer to the tip and back. So I believe it's a case of when the gearbox will go and not if.
