![]() | Home > Maintenance & Mods (L322) > Retrofit supercharged seats to 2002 model? Is this possible? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
John,
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
From what i've seen online the subframes use the same mountings. The only issue might be getting the seat module to talk to the car, even that just appears to be a BMW derived module though. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Not sure what seat the early sc cars had. If it's BMW type it should be pretty much straight swap. If it's the later one, I know it has an airbag in it, which is why you can't move the top bit about, as Pete mentions. 2011 Range Rover Vogue SE 4.4 TDV8
So you could just leave the airbag disconnected, on an earlier car (the car wont know it's there anyway)
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
Yep both front and rear seats of the 2002-2004 models are a LOT more comfortable than the ones in my 2007 supercharged. If I were you I'd see if I can't refurbish the current ones |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
The upper part of my MY 06 SC moves back and forth. Previous cars:
