![]() | Home > Technical (L322) > 2002 L322 4.4 zf5hp24 transmission problems |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
With that milage obviously it has not had the fluid changed before, if you describe it as "black" this isn not good with the milage that you have.
bmg1275 Member Since: 19 Aug 2015 Location: Dumfries Posts: 9 ![]() ![]() ![]() |
Flushed it through and also fitted a new oil cooler, it's done about 100 miles since and I checked the oil again and it is crystal clear, so it looks like a overhaul is due. |
belldarr Member Since: 14 Jun 2014 Location: Bucks Posts: 149 ![]() ![]() ![]() |
Hi Brian,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8719 ![]() ![]() ![]() |
Level won't make that much difference as long as it's something like...
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
when it thumps, do you get a BONG 'transfailsafe mode' etc.
Hi guys, Thanks for the replies. Oil level spot on and got up to temp, checked with a prob thermometer, don't get any notifications |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
We had a similar problem with ours going into Drive and particularly reverse, you revved the engine in reverse and very little drive, then a huge thud as it went it, no bongs or warnings, it turned out to be a crack in the valve block.
PaulTyrer, how do I send a request. I am a forum virgin! |
Phils profile page.
RRPhil has his PM's turned off, he would get hundreds a day otherwise...
Thank you |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
Hi Brian,
Hi Phil, thanks for the reply, changing the oil and filter made no difference. I can strip off the valve body and send it to you, could you pm your details and with costs of checking.
Hi Folks, An update on my transmission problems, contacted RRPhil and our first line of attack was to remove the valve body and have it tested/checked. I removed the valvebody which is a pretty straightforward job, even lying on your back, well anyway sent it off to Phil, a few days later I received a message from Phil saying that the valvebody that had been fitted to my car was an early zf5hp24 valvebody from approx. 1997,so for me this was good news( there has been loads of modifications/apgrades to the valvebodies since then) Phil suggested we try fitting the correct valvebody and take it from there.
