![]() | Home > Technical (L322) > 2004 L322 Battery Drain - searched and tried loads! |
| Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169
Thank you ALX! |
| alx Member Since: 13 Jul 2014 Location: Beds Posts: 99
Yep, the battery is glued to one of the modules, the Motorola thing is an aerial. You may as well have only one of these modules with everything integrated, not two. This tracker is from 2003. |
Thnx again ALX! Was your tracker marked in any way or did you have any other clues so you knew it was a tracker? |
It had a couple of meaningless numbers (like 5TRK0101UK. TRK = tracker?), which didn't produce any results when I searched the web. One number pointed to a discussion thread on some Honda forum where the owner was basically asking what these were as he found them in the car with people suggesting it's a tracker. |
yesterday several hours of looking for a tracker...... |
