Home > For Sale & Wanted > [For Sale] Digital TV Tuner For FFRR
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
Guys I have a digital TV tuner for FFRR and Sport available.
It is a correct for our cars part number AH42-19C063-AC, NOT the often found AW93-14F641-AE which does not seem to be working.
This tuner is plug and play for 2005+ cars with touchscreen main unit. You just swap your analog tuner out with this and it works.
Ready to go for GBP 310 shipped to your door.
Please PM if interested.
Post #347065 10th Sep 2015 4:17pm
jesssjames
United Kingdom 2006 Range Rover Vogue Td6 Stornoway Grey
hi have you still got this
Post #347373 12th Sep 2015 12:21pm
Sql
Please, check your PM box, I did PM you yesterday.
Post #347578 13th Sep 2015 7:01pm
Sql
Guys, please note these FFRR hybrid tv tuners do work work with mpeg2 only, which is not offen mentioned anywhere on the forums.
Most countries use both mpeg2 and mpeg4 so it is OK, but there are some that use mpeg4 only and this will not work there, so remember to check if your country uses mpeg2 for the digital tv.
Post #347990 16th Sep 2015 11:47am
Sql
Bump for digital tv in your FFRR
This tuner works with mpeg2 so it will easily work in UK, Australia, Germany, France and many more.
Post #348737 21st Sep 2015 7:01am
Sql
One tuner successfully delivered to France. Buyer reports that it works plug and play.
Still have two left (well in fact three as it turned out the one I had in my car from the beginning was a hybrid digital tuner already but they all do not work here as Poland uses MPEG4 instead of MPEG2).
Post #348940 22nd Sep 2015 2:52pm
n1cktdv8
Question?
If it's a digital TV tuner....could I assume you get the radio channels too ?
DAB Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #348951 22nd Sep 2015 3:29pm
Sql
No, unfortunately not. It has been discussed in a bunch of topics here, somehow these do not give you digital radio reception in L322. TV only.
Post #348958 22nd Sep 2015 3:41pm
Sql
I have one more of these available for sale -> 7H42-19C063-AA taken off a 2008 L322 Vogue TDV8.
Will work with touchscreen headunits and mpeg2 signal.
Ready to go at GBP 310
Please PM if interested. 12 4.4 TDV8 Vogue
Nara Bronze / Arabica / Ivory / Piano
07 3.6 TDV8 Vogue
Buckingham Blue / Sand / Piano
Post #381104 6th Apr 2016 10:37pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
My tuner arrived today after 5 working days so pretty quick.
Will plug it in tonight and hopefully have a wrking TV again in the car after a few years without!
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #382682 18th Apr 2016 9:13am
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Alex,
Don't make the same mistake as I did after I plugged my Digital tuner in:
Keys in ignition - ignition lights on - switch to TV - sound only no picture - uplugged - replugged - same - then I realised if the ignition lights are on then the car thinks it's moving so it switches the picture off Rolling with laughter
I hope this helps?
regards
John
Post #382700 18th Apr 2016 11:10am
zarnd
Ok, something to remember.
Thanks Alex
2007 M5 Touring
2004 SL55 AMG
Post #382726 18th Apr 2016 2:44pm
zarnd
Test fitted and works perfectly Alex
2007 M5 Touring
2004 SL55 AMG
Post #382762 18th Apr 2016 7:29pm
gpzjamie
United Kingdom 2006 Range Rover Supercharged Supercharged Santorini Black
is this still for sale ? thanks,Jamie jamie
Post #403279 4th Sep 2016 2:32pm
Sql
One tuner available now!
GBP 310. 12 4.4 TDV8 Vogue
07 3.6 TDV8 Vogue
Post #403765 6th Sep 2016 10:03pm
