Home > Technical (L322) > OBD Codes - P0036 & 56
red_slr
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zermatt Silver
My car is having problems (see other posts!) with revs hunting a low speeds (30mph) and on slight load (up slight hills).
I have just got a code reader and its showing :
P0036
P0056
Anyone know what the causes of this might be - also is the code P0136 the same as P0036?
Thanks
Simon. Range Rover Vogue 4.4 (2003)
Post #34736 3rd Nov 2010 5:08pm
daveo
Error Code P0056 shows up which is Ho2s Heater Control Circuit (Bank 2 Sensor 2)
Fault code P0036: Bank One, sensor 2.
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #34737 3rd Nov 2010 5:15pm
red_slr
Thanks. If I do an O2 sensor scan I sometimes get:
B1 S1 - OK
B1 S2 - OK
B2 S1 - OK
B2 S2 - OK
Then other times I get
B1 S1 - Not present
B1 S2 - OK
B2 S1 - OK
B2 S2 - OK
Would a faulty O2 sensor cause the revs to hunt and cause the car to judder at low revs? Range Rover Vogue 4.4 (2003)
Post #34743 3rd Nov 2010 6:48pm
daveo
i would think that if the o2 sensor was playing around then the mixture would be all over the place on that side...the ecu would be adjusting it to compensate, this could cause the hunting.. thats my thoughts but lets see what other members have to say... V8 facelift Range Rover Autobiography 22" wheels.
Post #34746 3rd Nov 2010 8:25pm
Mapmuppet
I experienced a faulty O2 sensor earlier in the year which pretty much shut down the RR and defaulted to a 'get me home' setting.
On a positive note they only cost about 80 quid but usually fail in pairs (apparently) Smile 2005 Audi A8 W12
1978 Mercedes 450 SEL 6.9
1986 Mercedes 420 SL 4.2
Post #34764 3rd Nov 2010 10:35pm
dan_uk_1984
What he said.
Post #34765 3rd Nov 2010 10:43pm
M44K TS
I had endless problems with 2 of the o2 sensors on my Maserati, revs were all over the place, limp home mode quite often, (370bhp and could only do 50mph tops Sad ) In the end, I had to buy genuine Ferrari ones as they were cheaper than identical Maserati ones, a snip at £239 each Sad 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #34767 3rd Nov 2010 10:47pm
