![]() | Home > Technical (L322) > Upper tailgate slams shut |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
The tailgate gas struts seem to offer no resistance when closing but are able to hold the tailgate open with no problems.
exalin Member Since: 14 Jan 2015 Location: Cheshire Posts: 69 ![]() ![]() ![]() |
Not damped on mine either. I was a little surprised at first but have now gotten used to lowering it down and then letting it close under its own weight as ajac described. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
Same here..... Not very classy ! 2011 Range Rover Vogue SE 4.4 TDV8
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
I always worry it's going to break the glass |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
I agree fish, I try to hold it under the letters R and A. I've had it unlock again when it's shut. I now avoid holding around the micro button bit that opens it. |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 ![]() ![]() ![]() |
Can't count the number of times I've cringed when sat in car and SWMBO gives it a good shove closed |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
That makes me cringe too! Especially when the teenage daughter uses it! Usually followed by a “sorry! Forgot again" |
Glad I'm not the only one that has that ^^ |
It is one of those things that I still can't believe that is happening to a premium vehicle like this. And if it doesn't slam hard enough, it won't bloody lock either well the 4.2 for sure.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
When I first got mine, had to really slam the upper tail gate shut. Did a bit of digging around and found that the latch mechanism in the lower tail gate was loose. Managed to take trim off, which gave access to tighten mechanism up (they are torx screws/bolts). That did the business and since then, tailgate shuts with barely a click!. Previous cars:
All my family members seem to have become quite adept at slamming the tailgate... and its always inevitably preceded by them faffing about with the parcel shelf with a bewildered look on their face because they STILL don't understand how to fold it back even after numerous demonstrations! |
scotbruce Member Since: 06 Dec 2014 Location: Aberdeen Posts: 39 ![]() ![]() ![]() |
This!!! |
