Home > Maintenance & Mods (L322) > Front and Rear Winch bumpers and swing away wheel carrier..
Page 3 of 5 <12345>
ebajema
Haylands wrote:
Stan & Craig... don't need PDC anymore, that's for sure..... Thumbs Up
You mean you don't need the PDC but whatever is on the receiving end of your bumper would wish you had it on Smile Smile Smile
Great job Pete !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #347768 15th Sep 2015 7:19am
Think you need a sure number plate Pete... Thumbs Up
Post #347818 15th Sep 2015 10:42am
miggit
Thumbs Up Looking very fine Bud Bow down
Just a couple of thoughts, as you still have lights and obviously intend to use this fine beast in the dark, is not a good idea to fit a number plate lamp?
Whistle I believe that they are a legal requirement in the UK Wink
And do you have to flatten your fingers with a lump hammer to open the tailgate? cos from where I'm sitting there don't look like there is a lot to get hold of Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #347829 15th Sep 2015 11:49am
pjb
love reading all your write ups Bow down
Fabrication & finish, way beyond what I could dream of doing, in fact I would never attempt
I think its better than 10/10
Keep up the good work Paul
L405 now sold
Post #347866 15th Sep 2015 4:28pm
Thanks chaps...
Craig, had a play with a square plate (I take it that's what you meant) but I think the long one looks better..
Paul, that's why I said nearly finished, number plate lights and reflectors on order from Hong China Taiwan Kong..!!!
Can still reach the button, just... my buttons a bit worn and unwell so I'm going to fit an external one behind the wheel....
Went to my mates today to crack on with the front but the steel didn't turn up till 2.45pm so we had a late one....
Had a look at the front, plenty of room for the winch once all the superficial plastic removed and the air con fan, don't need it any more since fitting the electric fans to the other side of the rad... It won't stick out any further than the original bumper... 8mm plate drilled to fit the original mounting holes, then 4mm winch plate welded to that, then start building from there...
Decided to cut the bottom off the front wings, much easier to do it that way...
Poor little Rangie looked a bit sad.... This is the top section made with a template from the original bumper with the ends modified to stick out past the wing a bit
Welded the front to the winch tray then the front to the top, weld and bend as you go, takes a lot of effort to get a smooth bend and not a kink..
Action shot... weld dressing...
First fit of bumper, note the extra long front piece at the sides to help with bending...
Cut out the front detail, this is for aesthetics to stop it looking so slabby and to help airflow as well as bolt the winch on... Also welded a return to it, makes it look so much better, this is all just tacked in place,
A hole cut for the winch with nice contoured edges, again with a return welded in place
It was all seam welded and ground back, gives the final bumper incredible strength...
More pictures of the front tomorrow.... Thumbs Up
Sorted out the spare wheel carrier, the "one bottom mount" idea didn't work very well, I used two saddle clamp bearings but the saddles weren't really up to the job and flexed a lot, I was trying to do it on the cheap as a mate gave me them to try...
Anyway design number two involved Heim Joints (Rose Joint) and a top mount as well... 14mm heavy duty joints and stainless fixings came to about �60...
Cut out and welded on two 8mm thick top mounts, ground down and painted.
Finally in place, it's now very strong and has no flex at all... Thumbs Up Thumbs Up
 Pete
-Click here for Thread-
Post #347933 16th Sep 2015 12:10am
Good job its NOT face lifted Pete! Or you would need MORE cutting off the wings! Shocked
Laughing Thumbs Up Bow down
Great job sir Bow down
Post #347952 16th Sep 2015 8:35am
i think you have a new nickname Pete, 'mad max' Laughing ... - .- -.
Post #347958 16th Sep 2015 9:19am
You need to be careful NOT to turn it into one of those riot control defenders we all remember in NI back in the day Pete Whistle
Post #347962 16th Sep 2015 9:24am
I'll change my signature Stan...
Craig, be a cheap face lift now, just a fillet under later headlights... Got any 2010 ones going cheap... Whistle Pete
Post #347970 16th Sep 2015 9:36am
Whistle Whistle Whistle Absolutely sir Whistle Whistle Whistle
Post #347972 16th Sep 2015 9:39am
Couple of quick photos... All done now, ready for its photo shoot tomorrow...
Light is poor at the moment I'll get some better ones up soon...
 Pete
Post #348219 17th Sep 2015 5:16pm
duckworthparts
Site Sponsor
top work Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #348220 17th Sep 2015 5:18pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Very nice Pete, top job Thumbs Up Thumbs Up
But why have you used wire not plasma rope, it's lighter, easier on the hands and just as good if not better than wire rope? If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #348224 17th Sep 2015 5:43pm
looks good... Thumbs Up
may i suggest a small hole mesh grill rather than the slatted you have...you could shape it better and there would be less likelihood of small branches damaging the air-con rad when you go off road..... ... - .- -.
Post #348226 17th Sep 2015 5:46pm
miggit
Bow down Someone's been a busy boy Thumbs Up Top job bud Bow down Yesterday I couldn't spell Engineer... Today I are one!
Post #348232 17th Sep 2015 6:23pm
Page 3 of 5 <12345>
