Home > Technical (L322) > Help!!! inactive EAS 05 Vogue
leeroyburns
Before I start!! Love my car!! 😃
I have a 2005 vogue with with dreaded inactive EAS warning light, also self level inactive etc - I have replaced the ECU and also replaced two front air bags. The car has completely lowered itself on all four corners and we are unable to raise the car back up to standard height. It almost like the EAS is asleep , there is no lights on at the rocker switch inside for selecting the ride height. We have tried all the usual items, lock to lock, battery reset etc
Any one any ideas, car has been off the road 8 weeks!! I want my car back!!!
Any ideas welcome
Post #348052 16th Sep 2015 6:10pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Dare I say it ... fuse ... but I guess you already tried that? Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #348054 16th Sep 2015 6:13pm
leeroyburns
Yes fuses, relates etc all checked, it's like the EAS is asleep
Post #348060 16th Sep 2015 6:35pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Pump?
Post #348062 16th Sep 2015 6:39pm
leeroyburns
Yes pump is operating / was told if you can force air into the system it should start to come alive but we can't get air into it!
Post #348065 16th Sep 2015 6:42pm
Have you tried bye-passing the compressor relay?
Have you tried putting 12V directly to the compressor?
Post #348072 16th Sep 2015 7:13pm
leeroyburns
No I haven't , never thought of that - that will eliminate any problems that end 👍 I'll try anything now
Post #348075 16th Sep 2015 7:16pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
If there are no lights on the EAS switch then its a hard fault that needs checking and clearing with a diagnostic tool before it will work again.
Post #348081 16th Sep 2015 7:43pm
as weejock says, clear the hard faults first .
Post #348084 16th Sep 2015 7:54pm
SMUTT
Just a thought has it gone into transport mode? Howard
Post #348106 16th Sep 2015 9:28pm
leeroyburns
That did come across my mind- any suggestions how to get it out of this mode?
Post #348110 16th Sep 2015 9:42pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Agreed Thumbs Up
Post #348111 16th Sep 2015 9:43pm
leeroyburns
My mechanic did try to connect it to the computer but it picked up everything but the EAS - is this a landrover job?
Post #348114 16th Sep 2015 9:57pm
johnboyairey
im sure this has been checked, BUT, have you reslammed all the doors, bonnet, and tailgates etc. these need to be all shut, (doors at least) for it to even 'get out of bed'
but 12v to pump sounds a good start to me.
if the pump is worn out, it runs for a long period, -if its not at a sufficient height, it times out, and stops, (to save iteself) and 'eas inactive' or something is displayed. then it may leak down to bump stops. and be horrendous to drive.
yes to fuse checking too.
if you know its the pump, it will be a new one from £300 (part price), or a repair to the pump seal was possible a year or so back, with a diy kit for about £25. dont bank on a secondhand one being any better than your original one. these pumps i think are made by a company called Wabco. you get a great big unit, and the pump is inside (a sound dampening tin) looks like a turtle asleep in the spare wheel well, or in another position, if car is LPG.
Post #348125 16th Sep 2015 11:25pm
