Home > Technical (L322) > timing belt
tone2711
United Kingdom 2006 Range Rover Vogue Td6 Java Black
timing belt
dear FFRR team
is the td6 2005 chain or belt timing belt, are all td6's upto 2012 chain or belt. Im a bit confused ?
If chain would it need a replacment at around 100thousand miles.
Ive checked wiki... but cant find.... or is it me being thick.
somebody point me in right direction... please?
tone
Post #348257 17th Sep 2015 8:27pm
TD6 is a chain and it should last forever...well almost forever
Post #348260 17th Sep 2015 8:59pm
Zirconblue
the TD6 was replaced in about 2007ish by the TDV8 (first 3.6 then 4.4) which are belt drive i believe.
TDV6's (not used in the L322, but were in the Sport and later L405) are Belt driven.
Post #348306 18th Sep 2015 12:52am
rar110
The 3.6 tdv8 in RRS & RRV has a timing chain.
The tdv6 2.7 & 3.0 in a RRS has front and rear belt. I think a similar 3.0 tdv6 has carried over to the L405 & L494.
Im not sure about the tdv8 4.4 in the L322 & L405. However I assume it's also got a timing chain. ______________________________
Post #348734 21st Sep 2015 7:20am
NONE of the engines used in any L322 models use a timing belt sir. They are all chain driven... Very Happy
Post #348749 21st Sep 2015 9:29am
dan_uk_1984
But don't let that fool you into thinking they are indestructible.
The M62 suffers from guide failure - resulting in a destroyed engine. Does the TD6 or TDV8 have any tensioners or chain guides etc?
Post #348830 21st Sep 2015 9:02pm
