![]() | Home > Off Topic > Help with Sanef Tag please |
Greg66 Member Since: 11 Nov 2010 Location: London Posts: 85 ![]() ![]() |
Tricky. Do you have it mounted on the bracket?
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi Craig, I think it has to do with the fact you try to pass through the toll at +150mph. 30 is a max speed, not a minimum !!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
Have driven in the Alps with mine though around albertville and bourg St maurice, no problems, as said is it mounted right, by the rear mirror?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
I worry about that every year, but normally relax after the first beep
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3275 ![]() ![]() ![]() |
If the battery has died you can still go through the manned toll booths. They take the details - number etc - from the tag and you pass through. They have all the information on the system covering you no matter which company has issued the tag.
I am 50/50 as to weather the area is covered but above someone mentioned the Orange T on the tag structure /drive through which I'm sure it had on both the last tolls...
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Only place I had an issue was heading out of Calais, after a quick chat with the toll booth folks there - they said it was normal for it to take time for the tag to register itself.
If you go through a manned tollbooth with the orange T then they will tell you if there is problem with your tag or not. Will save you searching for an office if it is OK.
Exactly my thoughts! But the car has NO heated screen! And has NOT been moved since Calais! Strange...
Not a problem, enjoy your drive |
Tag worked perfectly all the way to our destination! Don't figure... I can only assume the two tolls on route to chamonix are classed as Mont Blanc approach???
The Mont Blanc Tunnel péage is at the entrance to the tunnel and the approach road (a spur from RN205) is toll free. Seems strange that your "badge" wasn't recognised. Just a blip?
