![]() | Home > Technical (L322) > Newby with 4.2 S/C power loss any help would be great |
| j-hubbard Member Since: 17 Sep 2015 Location: Preston Posts: 4
I've tried to search the forums but if I am double posting please could you point me in the right direction...
Cheers for the reply ebajema - it sounds more like different pressures of air escaping at different revs, and not a squeal of slipping belt. Does the 4.2 have an air dump if it is under fuelling to stop it from running really lean?
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
i would guess its a small split/hole in a pipe somewhere which gets bigger under strain ... - .- -.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Stan you could be right. That is what I meant with the SC being loose or the gasket leaking because that is where the air is pressurized so it would go out. So air is leaving after being measured by the MAF and that makes the mixture more rich.
| SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77
I had a similar thing with my 4.2 which turned out to be a clogged air filter and under high rpm was sucking in the pipe between the air filter and inlet. Might just be worth checking.
| 3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301
I would be looking for a split hose, loose jubilee cli, etc. too, eliminate the simple, easy to check stuff first!! Regards Royston 2008 4.2 Supercharged Autobiography 1994 Classic Vogue SE 1999 Rover BRM 1987 Rover Vitesse Twin Plenum |
cheers all - i honestly didnt expect so many replies, as well as international, or any help with a boring fault.... I suppose it's about lack of power, one of the things we all buy RR for.
WOW...
| All times are GMT |
