Home > Technical (L322) > FBH
ije44
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
FBH
I'm two weeks into the ownership of my new RR. I knew it had a remote FBH but have not had the opportunity to use it in anger.
So I had to leave the house quite early this morning. It was cold and misty and miserable.
I opened the bedroom window (about 30 meters from the car), pressed the start button on the remote and left it running for 20 minutes.
Opening the door and getting in was an absolute pleasure. I know I can be easily pleased at times but this was just fantastic.
It is by far my most liked gadget on the vehicle. What a fantastic idea.
Definitely more accepting of the impending winter Smile
Post #348545 19th Sep 2015 6:39pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Great feature....but it takes a fair whack out of the battery Big Cry GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #348556 19th Sep 2015 8:33pm
ije44
Paul,
Yeah, I've read that on here. I suppose typically during the cold weather you also have heated seats, heated wheel, blowers and de-misters on a fair bit too.
One to keep an eye on.
Post #348560 19th Sep 2015 9:22pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I don't know if the RR is the same but the X5 Webasto version had a sensor that would not allow the FBH to work if the battery charge was too low. It would always leave enough battery charge to start the car. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #348579 20th Sep 2015 6:48am
ebajema
Worst case is that you have to install a charger and plug it in at night Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #348580 20th Sep 2015 7:22am
at least it worked when you turned it on!
around now until xmas there is usually a few members who have problems with the heaters!
Its is as you say a brilliant gadget, I tend not to use it too much on the FF but have installed a remote on the Disco and that goes on every morning in the winter, from the bedside table, so that when i go out the car is nice and defrosted! There is nothing that can't be fixed with a hammer😜😜
Post #348601 20th Sep 2015 10:50am
Brian
So, on this subject I have a TD6 Vogue but no remote is there an easy way to check that all I need to do is buy a remote from ebay and try it or is there a world of expensive bits waiting for me?
Post #348619 20th Sep 2015 12:38pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
http://www.fullfatrr.com/gallery/albums/us...G_3703.JPG
Hi Brian,
Look in the RHS fuse board in the boot and see if you have this.
It won't have the blue wire but might have the module.
If you have the module all you need is the remote.
If not you need both.
Post #348626 20th Sep 2015 2:03pm
Weegie
Brian, FBH was fitted as standard on the TD6. You are most likely to be missing the remote. John
GAP iiD BT-Sold
Post #348627 20th Sep 2015 2:15pm
mike whiskey
United Kingdom 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
You won't necessarily have the receiver, and your heater won't necessarily be enabledto use as a parking heater.
Is it available from the front screen under Aux ventilation?
MW
Post #348652 20th Sep 2015 4:53pm
Brian
I'll nip out and have a look now but problem no2 is that I have no front screen - the previous owner "upgraded" to a Kenwood all singing and dancing head unit Confused
Post #348757 21st Sep 2015 11:12am
Brian
Had a look see and don't see the module - I have a trailer socket thing (there is a tow bar) and few relays and fuses dotted about and one flat 4 pin connector sitting there doing nothing (but it's not a blue wire) - so not having a factory head unit, and no module I assume this would maybe be an expensive "toy" that I can do without - just something I can add to my "wish list" then Laughing
Post #348759 21st Sep 2015 11:20am
mike whiskey
You won't have the blue wire. That is a 'home made' antenna in lieu of the correct one. However having recently fitted Paul's module I can vouch for its effectiveness.
The flat connector you have free is probably the one you want, but should have 6 pins and three cables.
If fitted the module lives on the reverse side of the fuse and relay box. Maybe uploading a picture of your equipment bay would help?
Its not that expensive an upgrade. Paul very kindly sold me his unit for £65 and I used the IID tool I was going to buy anyway to enable the heater for working as a parking heater. My only snag was that having an early 2002 FF I had the old square connector, but I simply de-pinned it, insulated the pins seperately and used a picture from here to see which cable went to which pin.
I'm just waiting for a frosty morning now to try it 'in anger'.
MW
Post #348760 21st Sep 2015 11:40am
Steveo
Good evening all please excuse me but being a ex paratrooper we are not known for having a large amount of brain cells I have got a 2004 td6 and I have been looking to see if I have a fbh after looking at this post but the only setting I can find is AUX vent and a little red fan comes on is this the fbh or do I need to have it switched on at dealers ect regards Steve
Post #348816 21st Sep 2015 7:46pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
easy way of finding out if park heating is available to you is
find black plug for FBH reciver in fuse box side of boot should have 3 (might have 4 cant remember) wires going to it BROWN , ,WHITE&GREEN ,RED&YELLOW (and may have a RED)
bridge out the WHITE&GREEN and theRED&YELLOW wires with a bit of wire and if you have park heating it should fire up
cut the origanal plug off mine and conected a GSM dialer to start it up
Post #348892 22nd Sep 2015 11:10am
