![]() | Home > General > TD6 Aux Fuel Burning Heater Question - newbie 1st Post! |
You also have to consider your resale in a few years time, no one wants the HSE now let alone in the future. Also I didnt think Bi-Xenons were standard on the HSE? But may be wrong on this, my brain is frazzled from all the xenon/bi-xenon/halogen talk recently.
Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138 ![]() ![]() ![]() |
Im a bit confused here |
Depends what components you have already and what functionality you ant to get out of it? Do you want the timer, or do you want the remote? Or both? Do you already have the loom behind the fuse pannel in the boot? Have you looked at the workshop manual to see the component location diagram? You should then be able to see what bits you already have and what bits you need. If you read the link I posted about the discovery pre-heater the theory is the same... ![]() |
doublejay Member Since: 08 Nov 2009 Posts: 131 ![]() |
close....it's Full Fat round these parts. ![]() Welcome along. |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I wish I had read this post and the wiki before.
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 ![]() |
Aux heat and vent can be activated in a HSE and can be set on the mid unit or by remote activation if you plug in the reciever and get a fob what you will need is the ecu programing |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
cool. how do you set it to come on automatically using the MID unit? |
when ecu programed you have 2 selections on mid HEAT and VENT you just put the time you want it to come on same as you do with sat nav screen |
aneurysm1 Member Since: 12 Dec 2012 Location: burnley Posts: 202 ![]() ![]() |
get yourself a range rover and get the idea of a shogun out your head, they are just not in the same league. Whatever spec you are happy with, thats in your budget then go for it. I will be looking for one sometime soon and dont have money to burn, so at this moment i would be happy with any range rover because driving a range rover is what i want more than all the fancy specs! |
Ah, but spanner, the HSE only has a single Cd slot and no full screen as in the vogue so how do u set it using the display? |
when the ecu is programed it gives you the extra vent and heat options and you select them via the buttons under the mid display you also set the time for it to come on using the buttons |
cool. Now I understand. |
