![]() | Home > Technical (L322) > LR audio connectivity module |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Hi,
InVogue Member Since: 03 Nov 2010 Location: Cheshire Posts: 57 ![]() ![]() |
Would like to know about this also, I have a 2005MY with touchscreen nav. |
Shame, I was hoping for better iPod integration so I will stick with the Aux in and the cable trailing next to the passenger seat. |
It goes in the 2005 just as well - installation is a bit more involved, tho, as the dash pad has to come out. In 06, LR extended the harness to the glovebox and made the installation easier. With a little practice, the dash pad can be removed in under 1/2 hour. You do not have to remove the A-pillar trim, just be a little creative when tugging and shoving the L&R vent surrounds. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Thanks for the info - sounds a little more involved than I'd like though.... |
The most daunting part of the task (which really does sound much worse than it is), is removing the vents themselves. 4 clips must worked inward through the vent opening while you simultaneously pull on the vent to keep pressure on so they don't pop back into place. After that it's 3 screws on the left, 3 on the right and 11 (?) on top. If it were easier to remove the vents, I'd say 10 mins w/o practice.
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 413 ![]() ![]() ![]() |
For me, its the best 400€ i've spent on the car.
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 747 ![]() ![]() ![]() |
If you don't like the trailing wire from the rear AUX port you can run it into your top armrest, I can take a couple of pics of what I did with mine but basicaly I removed the Rear Aux port an plugged a headphone extension cord into the port and routed the cable through to the armrest. 2021 P400 Silicon Silver AB
