Home > Technical (L322) > Well that went well... not!
red_slr
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zermatt Silver
So, following my post about my O2 sensor codes I decided to change the rear O2 sensors.... bad move!
The front ones had previously come out with out so much as a bead of sweat..
The rears... cracked - turned about 1/4 turn and promptly stuck!
After much shouting and Big Cry they eventually came out... but the threads in the exhaust are fuggered!
Will now have to drop the entire system off the car (easy eh!) and try and tap out a new thread.
Anyone else had this problem? The o2 sensors looked factory - so well over 7 years old now.
New o2 sensors on order for tomorrow.
Any advice re the exhaust? Thanks! Range Rover Vogue 4.4 (2003)
Post #34894 4th Nov 2010 8:48pm
fisha
the exhaust is not as hard as you think to drop off the car. Just support it as best you can when undoing the nuts.
the re-fit was the hard part as its heavy and a tight fit in terms of tolerances of lining up bolts to holes on the headers. Again, having it well supported up to the car, but being able to shuffle it around when supported is the key.
It just slides out from underneath the car ... my thread with pics is here of a weld repair on the cat box...
http://rangerovers.net/forum/viewtopic.php?f=2&t=32757 V8 or else ...
Post #34921 4th Nov 2010 10:59pm
SteveMFr
Site Sponsor
If the thread is not too Censored , you can get a spark plug thread chaser and redo in situ. You'd need one that can be turned in the middle with an ordinary wrench (spanner Rolling Eyes ).
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #34926 4th Nov 2010 11:12pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I know the feeling, i turn an oil change into hard job. Last year i rounded off a sump bolt, then broke an easy out on it leaving that stuck in the bolt...... Big Cry Had to call a mate in the end, he welded a bar to it and it shifted.
Thats why i'm a draughtsman, i'm good at the technical stuff in theory only... Laughing 2004 black Vogue TD6
Post #34930 4th Nov 2010 11:31pm
red_slr
Sealey do a cat thread chaser £4.00... only snag 4 day wait!
Did it with an M18 tap in the end. Range Rover Vogue 4.4 (2003)
Post #34959 5th Nov 2010 12:40pm
red_slr
Exhaust is back on the car now, just about to re-fit the new O2 sensors and see what happens.
I dont think its going to cure my problem myself... but its the last option now really as I have tried almost everything else I can think of. Range Rover Vogue 4.4 (2003)
Post #34964 5th Nov 2010 1:03pm
red_slr
Fault codes have gone which is good.
However - my fault is still there.
I will post another thread about it... Range Rover Vogue 4.4 (2003)
Post #34973 5th Nov 2010 1:58pm
