![]() | Home > Technical (L322) > Trans Failsafe Prog - 2004 RR 4.4 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
you'll find this is a very common error message and could be a number of causes, try a search.. ... - .- -.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1036 ![]() ![]() |
A failing inhibitor switch or low battery voltage would be my guess. It would be worth checking if a P0705 error is stored in the controller.
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
I have heard that allowing the car to go through it's electronic checks before actually starting the engine can help solve spurious messages.
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
I bet it is the xyz range switch - as suggested check for codes |
