![]() | Home > Maintenance & Mods (L322) > Rear wiper clonking |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Mine does this. I think it is because the spring to hold the blade close to the glass has corroded and not longer exerts enough force, hence the wiper arm hits the underside of the spoiler/light fitting thing
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 ![]() ![]() ![]() |
Quite often caused by the hinge in the wiper arm seizing up with crud thrown up from the road. Park the wiper so as it is pointing downwards and free up with the likes of WD40 clean and lubricate the joint with Lithium grease or such. Should solve your clunk unless the spring has indeed corroded away. Should've been old enough to know better...doh!
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 ![]() ![]() ![]() |
Wd40 applied and fixed, great advise thank you yet again from the learned collective |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Good one to know as it is the sort of thing that would drive me nuts |
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 356 ![]() ![]() ![]() |
Sorry to bump an old thread, but this has just started to happen to mine. Tried the WD40 but to no avail. Although the spring visually seems fine. Is it new wiper arm time? |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
A new wiper arm doesn't cost a lot, if the hinge is seizing up then i expect it looks scruffy with pealing paint and the spring has gone weak anyway.
The rear wiper arm location is poorly positioned for washing and lubricating but perfect for the aesthetics of the FFRR. You need to remove the top rear spoiler (whatever they call it) to allow access to lubricate it properly and even when washing you need to switch the ignition off whilst the blade is in the six o'clock position. A FFRR PITA |
Cheers, looks like something for me to do next week. |
