Home > Technical (L322) > tyre pressure monitoring sensors and second set of wheels
zbol
Czech Republic 2010 Range Rover Vogue TDV8 Tangiers Orange
Hello. I am awaiting to be a new member with 2010 TDV8. And I want to ask a question about TPMS. If I will order a second (winter) seto of wheels - Do I need a second set of sensors? Or they can be moved from the original wheels? Or is it possible to turn the system off?
Post #34952 5th Nov 2010 10:34am
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Get another set, as they never come out intact Thumbs Up
Post #34961 5th Nov 2010 12:48pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Like nbunney said - they never come out intact - you might be lucky because your original set are quite new but I dont think they are supposed to be changed as often as you may change the wheel. The nut which secures the valve to the wheel is made of a very light cast alloy with a small seal which could get damaged.
I brought myself a second set of new alloys then needed to fit some TPMS sensors. The valve/sensors were reasonably expensive from Land Rover Parts for what they are I thought (approx £65 each) Neutral
I have seen a couple of sets available on the eBay in recent months, but quite rare (cheapest were approx £50 for the set) - however the lowest retail price I have found was from The TYRE EQUIPMENT COMPANY Ltd.
www.tyre-equipment.co.uk
They were the Genuine OEM Part (no.65741-67) which LR/Jaguar use themselves, manufactured by VDO/SCHRADER. I had to purchase a set myself a few months ago (£183.30 inclusive for 4) and they were delivered within 12 hours of ordering them.
Also - they are self programming, which means you will not need to have the Pressure Warning Light switched off by a dealer - they reset the light themselves within a few times of switching the ignition on/off.
Post #34975 5th Nov 2010 2:04pm
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Does anyone know if the OE sensors will fit D3 wheels (6 spoke 19" to be exact)?
Post #35153 8th Nov 2010 5:56am
Baben
...and for the best prices on any Land Rover parts or accessories - contact "The Large One" on the disco3.co.uk forum - he quoted me substantially less than the prices you mentioned above
Post #35167 8th Nov 2010 11:46am
