![]() | Home > In Car Electronics (L322) > 2005 Range Rover vogue TV not picking up channels ...help pl |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Not sure about the venture cam, but unless you have had the upgraded digital tv module installed you won't pick up the channels. |
Stewince79 Member Since: 27 Sep 2015 Location: Manchester Posts: 4 ![]() ![]() ![]() |
Well I thought that but then I bought a lot of ebay that was for my model that should have converted it but then it came and it didt fit after contacting the seller he then produced pictures of the modual in his car and mine was different he said mine was the digital one
There are a lot of rest of the world tv modules doing the rounds on ebay that won't work in UK cars.
All I know it's a diesel and 2005 but on 54 plate lol I'm crap with cars |
A 54 plate will have an analogue TV tuner , the newer hybrid tuner is in fact slightly slimmer and I think your Venture Cam has a gubbed batterie . When they start to die the led's work but there isn't enough juice to transmit . 2008 MY Supercharged
Its the swap over year so a picture of your unit would help.... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
pic in post now... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
If it doesn't have the spare green port then analogue? Just seen the pic - analogue IMO. John
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Is it? When i replaced mine the Hybrid unit is physically identical to the old analogue one. Looking at the pic posted above, that's an analogue one. Which is what mine had when i got it, the hybrid looks exactly the same but the label has the word "Hybrid" on it. It's a straight swap, but i found i had to use the IID tool to tell the car i'd fitted a digital/hybrid one to get it to display the channel names correctly. I also later used the IID to tell the car it was digital only, it makes it ignore the analogue band and find channels faster. There are basically 3 physical types of TV tuner fitted to the L322, The BMW one (non touch screen), the MOST one (touch screen) and the later Digital unit (2009 onwards). |
When I changed the tuner on my last one the Hybrid was definitely thinner because for a while I just slid it down next to the old analogue box and plugged it in and there wasn't nearly enough room for a same sized box . I then installed it properly later and it also had different spaced mounting holes , but It did say Jaguar on it and came from Wiggs . I assumed they were all the same but It's just as possible that there are a few choices that work . 2008 MY Supercharged
Yeah mine was just identical to the original, there was no way it would fit in there without removing the old one. (it's a complete pig of a job to remove the old one, for what looks like a simple task.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
My 2007 runs an analogue TV and tbh.....I can't think of a worse combination of TV+Car !!
