![]() | Home > General > BMW 4.4 V Jaguar 4.4 version |
Jag engine is very good. I had it in 2 Disco 3's. BMW engine is a little more eager. |
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 ![]() ![]() ![]() |
The bmw engine on the other hand is far more common, easier to work on and the parts are cheaper and more easy to find. L322 Vogue 2003 |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Jaguar lump has slightly more power and slightly more torque but slightly higher in the rev range. I think the fuel economy is about the same. In terms of the numbers they're fairly evenly matched.
I've read on here a few times that the Jag engine is the preferred one but there are very few with them in as they started to come online as the SC engines got fitted and most went for that i believe. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
I had a BMW V8 FFRR for 4 years/12k miles. The only engine related problem I had was the small coolant hose at the back and the electronic thermostat. Both easy/cheap fixes
Oh, and i think im correct in saying there is no stupid water cooling of the alternator on the jag units |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 794 ![]() ![]() ![]() |
Checking my various lpg connections now as I want to lpg the jag 4.4. I know that there are reports of valve seat problems but an electronic flasflube type of kit should sort that out and I would be using one of the best conversion companies in the North West.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Ran an AJV8 for 18 months - very good.
I think the jaguar 4.4 is more common in the US as an economy choice, where diesel is less popular. In the UK people either bought the TDV8 or went for the more powerful supercharged 4.2. |
I'm not saying it's a bad engine, but it's not really that superior to the Jaguar unit. |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
But surely the point here (as mentioned above) is that the BMW 4.4V8 has the cream cheese 5 speed ZF auto box and the Jag 4.4V8 has the much acclaimed and well sorted 6 speed ZF.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8767 ![]() ![]() ![]() |
True enough, but the 5speed zf is now where near as fragile as the gm unit. |
I has always been under the impression that both the ZF and GM 5 speeds were as bad as each other but just in slightly different ways! There are pages of debate on that on here though so I am not looking to open that can of worms! I had the TD6 / GM box and I always thought it was a very pleasant, relaxed drive. This forum frightened the life out of me though so I shipped out before it went pop.
It does seem the GM box in the TD6 is far worse. There are lots of posts about doing expensive flushes on the 6 speed ZF.
