![]() | Home > Maintenance & Mods (L322) > squeak in rear end |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
It may be the upper rose joint on the suspension, I think these fail and sound like an old pram. it's on my "tuit" list.
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
Yes the rose joints.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8817 ![]() ![]() ![]() |
Yep, what they said... don't buy cheap ones, genuine ones from Dan are less than £40 each and it's worth getting new bolts, nuts and washers, Also worth getting the suspension set up afterwards as the bolts control the rear camber... Pete
marky777 Member Since: 05 Mar 2015 Location: Christchurch Posts: 141 ![]() ![]() ![]() |
Just done the rear o/s lower rose joint on mine 1 week ago. The noise was so annoying. Get it done at an indy, MD cost me £275 and the part was only £38.50
Blimey... did all four of mine in about two hours... must have been a very hard to remove bolt..... Pete
marshy Member Since: 20 May 2014 Location: Adelaide Posts: 34 ![]() ![]() ![]() |
Thanks gents will sort it out soon |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Yep sounds like a rose bush. Mine was squeaking for a while, it sometimes sounds like an old spring mattress. Quite a cheap job from an independent if you don't want to do it yourself. No longer FF owner but still interested. Present car Jaguar XE
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
Mine seems to have developed this "squeaky pram syndrome", but;
I went over the whole front suspension on mine as I'd have put money on it being the front but it turned out to be the rear hub joints... As the front wheel goes over a bump the rear moves as well, you feel the bump from the front and then it squeaks so it appears to be the front...
Okay, thanks - we'll see what he says.
