![]() | Home > Technical (L322) > Welding exhaust in situ ... |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Disconnect the battery and leave for an hour before welding sir... Never had an issue and have welded countless 322’s sir |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 ![]() ![]() ![]() |
Thank you kindly Craig.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
And try and get your earth clamp as close to where your welding, without getting in your way, as this also reduces the path that the current has to flow and reduces the risk of it frying any ECU's Yesterday I couldn't spell Engineer... Today I are one!
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It's a good idea to earth both sides of the weld with a jump lead. That way the welder wont earth the other half of the weld through the Lambda sensors and ECU.
Are the pipes on the early cars stainless? I thought they were mild steel sir |
Definitely stainless on my 2004 (2005MY) It's possible they changed to higher grade stainless for later ones, some of the lower grades of stainless will go brown (where road salt bakes onto them) and even develop a slightly rusty appearance when they get hot (like the cat/manifold end kind of hot), but that's as far as they go and don't rot like mild steel would. The higher grades discolour slightly with heat but still stay shiney. It's a little bit like how Bronze statues go dark brown then stay that way or centuries.
Yeah fair comment, and most of the Range Rover's exhaust is pretty well hidden anyway. I just happened to have some stainless wire when i did mine, came out ok, maybe i was just lucky. ![]() |
Using stainless wire on mild steel and mild steel wire on stainless should have the same outcome, but I'm only guessing now. Using the wrong grade stainless wire on stainless steel is a disaster, as is using the wrong gas, it will cause porosity in the weld, and can also cause the weld to crack |
As i said, i was probably just lucky with mine.
The trouble with alli is there is a fine line between weld and blob |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
Well mine defo isn't stainless, maybe someone fitted a later system to yours Zirconblue as I've not seen one on an early one yet...
The hours wait is lunch time |
