![]() | Home > Maintenance & Mods (L322) > brake pad warning light but cant find any faults |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
I replaced front discs and pads a few thousand ago ( no warning lights at that stage ) and ive just had the BP warning light coming on /going off through a journey.
ah ok thanks , I thought the sensors was activated on a earth through the wire to the disc , if its a open circuit activation I will close both loops and I should be good, thanks |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
If it's anything like BMW.there is a resistor in the sensor and the ecu will only turn the light off if it sees a new sensor (different resistance) on the end of it,so a sensor change may be needed even if the pad wear has not got that low
don't think its that Iron horse because I changed the front and kept the original sensor and I was ok for a few thousand , I'm sure its the back one that was disconnected and taped up, probably an open circuit under the tape |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Just get a new sensor they are less than £20, and are plug and play. |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
When I replaced the rear pads the sensor was cracked at the elbow of the pad insert, I successfully broke it, and had a rear bad warning, bought a new rear lead from LR, fitted it and after a couple of minutes, the warning reset itself was @£20 for gen LR Regards
think beyond the box (its a rangerover) Tha pad light comes on when the ecu thinks you need new pads not necessarily when they have worn out,depending on how hard you are on the breaks depends on if you beat the ecu thinking they are worn out |
