![]() | Home > Maintenance & Mods (L322) > Engine carbon clean / Terraclean... |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1486 ![]() ![]() ![]() |
I was thinking of having mine done but not had done yet?? |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
There also seem to be two types, Terraclean is fed through the fuel system and cleans the internals this way. There are other companies offering engine carbon cleans which is a hydrogen gas which is fed through the air intake system. Not sure which type is best suited to the RR |
I found this elsewhere on the net which is interesting
babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142 ![]() ![]() ![]() |
Yes - I've had my 2009 TDV8 Terracleaned @ around 80,000 miles
Thanks, that's good to hear. I think I will get it done on my old td6 as it needs all the help it can get. There is an agent just up the road from me also |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
I was also thinking about having this done but instead decided to try and give it a bit of a clean out myself.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3288 ![]() ![]() ![]() |
I might be wrong, but on the 5.0 I can't see this making that much of a difference as they are direct injection. I think these are fed in via the fuel system on traditional cars to remove carbon from the back of the valves etc.
Hi yes that's correct on the 5.0 the hydrogen gas clean would work though and that goes through the air intake system instead. |
Car is booked in for a Terraclean next wed so will report back my findings |
How did it go? |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Be keen to hear how this went on a 3.6 as I am considering mine Is this where I put the car details and a bit about myself ?........ |
bdc6570 Member Since: 31 Oct 2015 Location: Southampton Posts: 1 ![]() ![]() ![]() |
Had one done on my D3 last year... mpg stayed the same but the engine felt much smoother! planning to get one done after the next service on the old girl.. |
Hi, i would highly recommend the terraclean, on my TD6 it has made a big difference. Car is now much smoother when driving and mpg has improved by around 2-3 mpg. Probably the best £100 i have spent on the old girl |
It will not fix sticky EGR valves though. As a general clean probably helps. |
