Home > Technical (L322) > Can I trickle charge my battery in situ?
Page 2 of 4 <1234>
wilwak wrote:
Does anyone know where the actual battery is located?
On an L405 it's under the spare wheel
There's also an additional smaller battery behind the side panel on the drivers side of the boot Thumbs Up
Post #350479 3rd Oct 2015 1:45pm
wilwak
United Kingdom 2016 Range Rover Vogue SE TDV6 Corris Grey
Thanks Smile
I think I may try to rig something up to the jump points under the bonnet and leave a fly lead poking out somewhere.
It's more difficult in the rear due to the fancy electric tailgate.
It's a pity more manufacturers don't fit an exterior connection point for a maintainer. I know Bentleys have them by the number plate and provide a branded CTeK maintainer with every car sold.
Would be a nice touch on a high-spec vehicle.
Post #350504 3rd Oct 2015 5:47pm
wilwak
All sorted. Smile
CTeK fly lead all fitted to the under bonnet jump points
Connector routed to bottom corner of windscreen. All seems good. Smile
Amazing vehicle. Very impressed so far.
Post #350639 4th Oct 2015 7:40pm
miggit
The 13 pin trailer wiring also has a direct link to the battery, and will perform the same function as the 12S socket, or you could always plug into a power socket in the boot or one of the many console ones as they are all live all the time (2003 BMW Spec, don't know about later years) Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #350661 4th Oct 2015 10:38pm
wilwak
Thanks. I'll have a look for the trailer wiring. That would be a perfect solution if I can find it.
Post #350668 4th Oct 2015 11:09pm
miggit
If you've got a tow bar then you'll have wiring, and then it will have either 1 or 2 sockets, they are tucked up under the bumper to the left of the trailer hitch. If you have 2 sockets then you need a 12S plug to get the power into the battery, goes in to the white socket. And if it's a 13 pin then a 13 pin plug is needed, and if it's just a single 7 pin socket (12N) your screwed Shocked
Then I'd look at a lighter / accessory plug, and plug in to the power socket in the boot by the light, and shutting the cable in the tailgate, if you use figure of 8 wire it will not interfere with the the closing and locking of the tailgate Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #350672 4th Oct 2015 11:32pm
wilwak
Thanks.
I don't have a tow bar but I assume the wiring will already be there somewhere.
I think you may be right that the rear boot power socket may be the easiest solution. Good to know that the cable will trap in the boot lid ok.
I'll keep playing....
Thanks again.
Post #350679 5th Oct 2015 7:57am
On L405's that have a factory tow bar - it is electric deployable which means the 13 pin socket disappears under the car and isn't easily accessible when the tow ball is away.
Similarly, the wiring isn't just sitting there in a convenient place....
I'd stick with what you have Thumbs Up
Post #350685 5th Oct 2015 8:57am
wilwak
Ok thanks.
I'll stick with what I've done for now and keep looking for a better solution.
I may look at hard wiring it to the battery under the spare wheel if it's possible to have a trailing wire out the tailgate.
The problem with rear boot solutions is that I can't open my tailgate once the vehicle is in the garage. No headroom.
If I find the perfect answer I'll post it up on here.
Post #350687 5th Oct 2015 9:23am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
My 2006 only has permanent live on the boot socket. All the other power sockets are via the ignition.
A C-Tek is currently attached to the boot socket and the cable runs out via the tailgate and into the garage where it's plugged into an extension lead.
The extension lead cable is unravelled from the drum as I understand if left on the drum the cable can get hot. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #350688 5th Oct 2015 9:26am
miggit
Wilwak, can't you put a breakable joiner in the lead? you could plug in to the power socket, shut the tailgate and leave your joiner on the outside, before you go in to your garage Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #350693 5th Oct 2015 9:59am
wilwak
Yep. That's what I'd do. Use one of the Ctek Extender cables.
Post #350698 5th Oct 2015 10:32am
Martin
Site Admin
Seems a good thread to plug my wares Wink
http://www.disco3.co.uk/shop/tow-electrics...c-p45.html
12S or 13 pin version and for various charger types.
Post #350733 5th Oct 2015 2:18pm
miggit
I knew I'd seen them somewhere Thumbs Up , just couldn't remember where Embarassed Yesterday I couldn't spell Engineer... Today I are one!
Post #350735 5th Oct 2015 2:23pm
miggit
Martin, do you do one to an accessory plug as well? Not every one tows Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #350736 5th Oct 2015 2:25pm
Page 2 of 4 <1234>
