![]() | Home > Maintenance & Mods (L322) > Sound Proofing |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Interestingly the quietest tyres on camskill in a 255/50/20 seem to be Hankook:
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 193 ![]() ![]() |
Just been out to have a look at the spare wheel compartment and I can't see any sound proofing in there at all, just bare panels and floor, I think I will buy some dynamat or equivalent and have a go at sound proofing this area.
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
You need to be young and small so you can straddle the wheel well. Or if you're old enough JLR assume you can pay someone to do it for you... |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I'm sure in the manual, it shows you that lifting the 'lid' with the strap connected, it slowly lifts the wheel, then you pull another strap to tug it out.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2712 ![]() ![]() |
No lift strap on my MY12 so just have to stand inside facing out the back and lift the wheel straight up then onto the tailgate. |
Ironically I find it easier with the tailgate shut because being a shortie I can lift without reaching over too far. Ed |
Spare wheel lifting strap available to retrofit, bolts in behind the wheel below the rear seats, loops under the wheel then when you need it hook it into the top of the lower tailgate and drop the tailgate down, this lifts the wheel so it can be slid out |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
Yes as above... Retrofit the 02my strap system |
I managed to get the spare wheel out after a bit of huffing and puffing, I needed to do this as I want to sound proof the spare wheel well. The next time the spare is needed, I will be calling the AA.
Well I prepared the spare wheel area for sound proofing
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7937 ![]() ![]() ![]() |
Looking good. Just hope that foam doesn't get damp or wet or it'll smell a bit..... 2011 Range Rover Vogue SE 4.4 TDV8
I did mine today although basically only the flat areas in and around the well - silence is golden! The front needs attention now so will start a couple of exposed side panel areas under the bonnet. |
Have you considered the lower tailgate at the rear. I found it has no sound deadening material in it all and was very "tinny" when I tapped it. Adding sound deadening sheet significantly improved it.
I don't hear engine noise even though the engine acoustic cover is not fitted, only reverberation from the BFG AT tyres. The noise seems to mostly be emanating from the ends of the fascia although I know that the source of noise is often hard to pinpoint. |
