Home > Technical (L322) > FBH Sort of
Ziggy
Australia
FBH Sort of
Can you set up the remote for the FBH to work the air con? I have looked in the book but it only mentions heating
Don't need the heater so much, but being able to switch the air con on 10 mins before you got into the car would be fantastic
Tar
Zig "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #350963 7th Oct 2015 6:30am
ebajema
Hi Ziggy, that would only work if the AC compressor is driven electrically and not mechanically of the engine or if the engine is running (i.e. remote starting). I'm not aware that the functionality is there anyway, pretty sure not but wouldn't it be great in warm places or on warm days to have a bit of cooling before you get in.
I'm pretty sure that in electric cars this is certainly possible and it wouldn't surprise me if a cars like the Tesla S and X actually have that functionality built in. MY 2010 5.0 SC Galway green and sand interior!!
Post #350964 7th Oct 2015 6:46am
mzplcg
The FBH does double as a ventilator though. I used to use the timed climate to bring on the fans 10 minutes before I left work. It just uses the heater fans to ventilate the car. Not perfect but much better than raging hot if it was sat in the sun.
Post #350965 7th Oct 2015 8:28am
Zirconblue
Yes, in the summer it operates as remote/timed ventilation. Just takes the edge off the temperature.
I noticed some Audi's have a solar panel in the sunroof, that runs the ventilation fans when it's parked in the sun. Shame the Range Rover didn't come with that.
Post #351026 7th Oct 2015 2:50pm
mzplcg
That's a double edged sword. My humble Skoda Superb has it and it does work well. But it also means a new blower motor every 2 years. Laughing
Post #351033 7th Oct 2015 3:26pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I think the cut off ambient temp is 15 degrees for heating. higher than that it will ventilate via the remote. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #351048 7th Oct 2015 5:35pm
I have used it a few times but frankly when the car has stood out in the sun at 43 degrees all day it makes sod all difference Big Cry 2008 MY Supercharged
Post #351143 8th Oct 2015 3:10am
You can walk up to the car and hold the unlock button... After 3 seconds or so it opens the windows and sunroof until you let go of the button sir...
If yours does NOT do that then it needs enabling in the CCF, but is possible sir Bow down Thumbs Up
Post #351164 8th Oct 2015 8:26am
Ziggy
Australia
Thanks Guys
I must be having a blond moment, I cant get anything to start off the remote for the FBH
Cam-Tec your a Censored Laughing , when I read your post I went out and tried cook thought I was mad 10pm pitch black and I'm out playing with the rangie Rolling with laughter
Alas it did't work no windows opened. Big Cry ....where would I look in the ccf to enable it
I think somebody needs to do an idiot guide on what you can do with the IDTool as I'm sure I'm not using it to its full potential
Zigg "Those who cannot remember the past are condemned to repeat it."
George Santayana
Post #351301 8th Oct 2015 10:01pm
its called lazy lock/ unlock mr zigg.. ... - .- -.
Post #351330 9th Oct 2015 8:31am
Ziggy
Australia
AAAH-AR Idea Sir Stan I'v seen that............so what do you do with the gizmo when your in the lazy lock /unlock page
does one set it to lazy unlock or what.............I'me great with a hammer not so good with techno s**t
still aint got the TV working and I'v been playing with the setting in the ccf on an off for months now Whistle
George Santayana
Post #351331 9th Oct 2015 8:42am
do this,
Body Control:
Lazy Lock From Door Key
Lazy Lock From Remote Handset
Lazy Unlock From Door Key
Lazy Unlock From Remote Handset ... - .- -.
Post #351333 9th Oct 2015 8:59am
