Home > Technical (L322) > Can I trickle charge my battery in situ?
Page 4 of 4 <1234
wilwak
United Kingdom 2016 Range Rover Vogue SE TDV6 Corris Grey
Just a heads up....
The boot socket in my 2016 L405 isn't a permanent live!
Is is whilst the car is unlocked but then deactivates when locked.
Sad
Post #351359 9th Oct 2015 11:22am
It's complicated with an L405 as it has dual batteries.....
In the boot, the side panel on the drivers side comes out - there's a fuse box behind there - you should be able to find something permanently live - but even then you'd need to figure out which battery it was connected to when the ignition was off.
I'd run a cable up from the main battery itself which is under the spare wheel
Post #351361 9th Oct 2015 11:58am
Page 4 of 4 <1234
