Home > In Car Electronics (L322) > Towbar ECU mapping.
PeteH
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Towbar ECU mapping.
Hi guys. Range Rover Vogue. TDV8 2010... Has anyone any idea where I can map my ECU. To accept my new towbar.. It flashes on the indicator. (Towbar symbol) so all is well. But continually beeps when reversing.... Very annoying...
Many dealer wants £94 plus vat??? Told it takes 10 mins...with the right equipment.
I live in Manchester..
Cheers guys...
PeteH
Post #351289 8th Oct 2015 9:03pm
i believe that an iidtool will do this job, worth investing in one.. ... - .- -.
Post #351291 8th Oct 2015 9:15pm
PeteH
Thanks.
I will look into it...
Peteh
Post #351294 8th Oct 2015 9:33pm
supershuttle
As ever Stan is right, I did mine with the IIDTool although it gives lots of options I just set mine to 13 pin and it seems to work fine although I have 7 N and S Geoff
Post #351706 11th Oct 2015 5:52pm
PeteH
Thanks. That's great....
I don't think I ll buy one. Though . For a one time use. Any one have one in Manchester. That can do it.. At a cost, obviously...
Thanks.
PeteH
Post #351723 11th Oct 2015 7:19pm
supershuttle
You're more than welcome to use mine if the BT version will do any car and you don't mind a quick jaunt down the M61 to Chorley if you don't get another offer sooner. I won't be able to help 'till Wednesday though. Geoff
Post #351742 11th Oct 2015 8:54pm
The regular IID is mapped to a a single car - it can support multiple, but you will need an additional licence.
A 'Pro' version can program any car
A regular will read faults of any car, just not make updates
Dan can sell you an additional car licence
Post #351744 11th Oct 2015 9:11pm
PeteH
[quote="supershuttle"]You're more than welcome to use mine if the BT version will do any car and you don't mind a quick jaunt down the M61 to Chorley if you don't get another offer sooner. I won't be able to help 'till Wednesday though.[/quot
Will it work on another car, as allister says, need the pro??
I'm busy also, til wed. Thanks
PeteH
Post #351751 11th Oct 2015 9:35pm
https://www.gap-diagnostic.com/products/iidtool/
Second line of the table Thumbs Up
Something like £75 for a second VIN - so if it is truly a one off, may be worth just paying the £94 locally
Have a scan of the above web site & see what else can be changed & get it all done in one go - either with Geoff or the main dealer Thumbs Up
Post #351756 11th Oct 2015 10:09pm
PeteH
Thanks for your help , guys...
Post #351759 11th Oct 2015 10:16pm
Just looked back - Dan was doing the VIN addition for £60 in May - not sure if that's still the case Thumbs Up
Post #351760 11th Oct 2015 10:19pm
