|  | Home > Technical (L322) > L322 4.4 Petrol fuel pump |
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215      | I cant say that I have ever heard mine.
|  2nd Oct 2015 1:26am |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277      | the Fuel filter is also the pressure regulator, if it's blocked up it'll cause fuel starvation, and it'll also put too much back pressure on the pump and eventually kill that. | ||
|  2nd Oct 2015 4:17am |
| Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132      |
 Well I changed the fuel filter as suggested by RR P38 and then took it for a blast - and so far so good. I can still hear the pump switching on and off, but maybe that is what it does - build up the pressure and then backs off!! Further investigation needed.
|  3rd Oct 2015 10:03am |
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215      | Good stuff....fingers crossed.
|  10th Oct 2015 6:53pm |
| Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132      | Didn't get anything out of the filter. It had obviously been changed before by previous owner because one of the collets was broken and replaced with clips and pipe. However, it had another 'moment' on Thursday so not so sure I've cured it!!
|  10th Oct 2015 10:13pm |
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215      | Get fuel rail pressure tested next. I think you are looking for 3.5bar. | ||
|  10th Oct 2015 11:42pm |
| Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132      | Ok will do. Hopefully I can do that with my iid tool  | ||
|  11th Oct 2015 12:27pm |
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215      | I dont see any sensor for fuel rail pressure in the w/s manual.
|  11th Oct 2015 9:42pm |
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215      | The reading here is interesting.
|  11th Oct 2015 9:49pm |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035      | If your pump is on the blink, then there is a WIKI to show you the steps to change it. This v8 model does suffer from a tired pump. And my symptoms were hardly any power, and OK for a bit soon after. Then sometimes no starting etc. Ie low fuel pressure etc. You might want to measure the actual pressure via a cheap tool Via eBay etc. it hooks onto the engine fuel rail. | ||
|  11th Oct 2015 10:57pm |
 All sorted! Ordered a new pump and it arrived in less than 24 hours. Using the 'wiki' info was able to fit it without too much bother - Result!
|  27th Oct 2015 4:48pm |
| Posting Rules
