![]() | Home > Technical (L322) > 4.4 V8 gearbox issue (04) |
PaulNorway Member Since: 12 Oct 2015 Location: Oslo Posts: 3 ![]() ![]() ![]() |
What is the correct oil for L322 4.4 gearbox and how mutch oil does it take. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
Mobil lt71141 ONLY, there are no alternatives no matter what garages tell you, they will have the same specifications and will say they are an equivalent but they do not have the same additives that the 71141 has...
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 ![]() ![]() ![]() |
I've done 10,000 miles since having the gearbox oil changed to the 'correct' fluid and it's been fine. The 'metallic whirring sound' I've also stopped: I decided to check my own gearbox oil level using my iid tool to check temp - I managed to get the best part of a litre in, the result being no more 'whirring' sound!!! Thinking about the oil change my own garage did, I wondered how they managed to drain, fill, drain, fill etc whilst maintaining the correct temp in such a small space of time?? Sometime I wonder if there are any garages you can totally trust to do the job right!!
