![]() | Home > In Car Electronics (L322) > How to fit iPhone socket |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35743 ![]() ![]() |
something like this will probably work,
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Thanks for the prompt reply 2015 4.4 AB
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Something into the 3.5mm jack or the genuine Land Rover kits are about the only way.
Thanks Nmj. I was looking for something more like a splitter for the existing Aux that I could run up under the cup holder
sherman Member Since: 23 Aug 2015 Location: L'Isle Jourdain Posts: 71 ![]() ![]() ![]() |
This was posted by GraemeC and is the way I plan to go with my 2007 Vogue SE?
I had a 3.5mm and old style iPod connector/splitter in my 3.6 and this worked fine, though for newer iPods and phones then you will need the apple 30 pin to lightning converter as the new phones don't have a DAC built into the phone like the old ones with the 30 pin so you need it to convert from digital to analogue so the 3.5mm jack will make noise..... There is nothing that can't be fixed with a hammer😜😜
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
I got a longer 3.5mm cable and ran it behind the trim to the sunglasses holder then ran a 12v socket there as well. I have my iPod in a magnetic holder in the glasses holder and its jailbroken so it stops playing when the ignition is turned off. This way I don't need to keep putting it away I just close the holder. |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
I got two long leads for mine and an iPhone dock I use mine for an iPod touch and it sits nicely in the cup holders it's a compromise but it works
33sport Member Since: 24 Jul 2015 Location: kent Posts: 82 ![]() ![]() |
I fitted one of these, works a treat
Thank you all. 2015 4.4 AB
Hey 33Sport, that looks a lot neater than the way I was going to go.............is the sound quality up to scratch...........and are you running an iphone or ipod please?
hi Sherman
baldnSlick Member Since: 13 Sep 2015 Location: London Posts: 20 ![]() ![]() ![]() |
I did what someone suggested to me, I bought a neet airstream which is similar to an Apple TV connect that to the aux and place it in the centre console, you then connect to the airStream using the wifi and then use AirPlay function. My daughter has a non cellular iPad and I have a car charger wifi that can connect 10 devices, yeah you need another data plan but it works. I also have the dealer iPod connector but it is not lightening so it is pants.
