| Steering column auto position | |
While getting out of my 08 RR Vogue this evening having switched off the ignition, the steering column moved to its upper position (as per normal) but I could hear the servo motor continuing to run after the column had reached it upper position. When I put the key back in the ignition lock and restarted the engine, the servo motor continued to run with the column in it upper position. I found I could move the column ok with the small adjustment column on the lower left of the column housing, however when I turned the ignition off, the column again moved to its upper position and the servo motor continued to run for around 10 sec before stopping.
Not sure what the problem is, but any ideas / advice welcome
Chris 08 Range Rover TDV8 Vogue
