Home > Technical (L322) > fuel gauge.. bit of a strange one?
tone2711
United Kingdom 2006 Range Rover Vogue Td6 Java Black
filled the FF to the absolute brim yesterday with Dielsel (under instruction from SWMBO coz she wants her 10X nectar points). I know the tank is full however the fuel gauge when i shift to neutral the gauge drops to empty.. as soon as i put into drive goes back up to full. Any ideas anyone.. Every other gauge/gadget working perfect???.
thanks all Tone
PS.. there was still a 1/4 tank when i filled her up (the FF not the mrs) so i had not run it to anywhere near empty remaining silent when one should be protesting makes cowards of brave men.
Post #351880 12th Oct 2015 6:22pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Does the 'miles left' change at the same time? Thumbs Up
Post #351881 12th Oct 2015 6:35pm
tone2711
Re: fuel gauge.. bit of a strange one?
thanks all Tone
hey thanks for reply
no its stays at around 420 range remaining? i will look tomoz though again whilst driving work.. could that be an issue if range changes? what could it point too? remaining silent when one should be protesting makes cowards of brave men.
Post #351882 12th Oct 2015 6:39pm
tone2711
hi rosco
thanks rosco for reply
no stays around 420 range.. i will check tomoz though. what could it be any idea?
tone remaining silent when one should be protesting makes cowards of brave men.
Post #351883 12th Oct 2015 6:42pm
the gauge is governed by the 2 in tank sender units, it basically takes an average of both of the units, and displays this as the reading. It could be that one of the senders is at fault and the gauge is having a dicky fit dos it doesn't understand the inputs its getting.
not sure it really has anything to do with the D/N position, could just be giving it a bit of a jolt to a good bit on the potentiometers.
mine 3.6 did the full to empty gauge thing just before a trip to france and it was sorted by swapping the in tank senders. not a cheap item or clean job though......
One way to prolong the inevitable is not to fill it to the brim Thumbs Up should be able to get away with a few more months then before it needs changing. There is nothing that can't be fixed with a hammer😜😜
Post #351885 12th Oct 2015 6:49pm
Rosco
Sounds like one of the senders to me, common issue, as long as the miles left doesn't change it should be a sender, pain in the proverbial but sometimes sort themselves out, not much help I know Thumbs Up
Post #351889 12th Oct 2015 7:02pm
M3DPO
Coming from the D3 side I can only explain the characteristics of a D3 and add I have had experience of this "feature". The easiest way to explain it is imagine it is a clock(timepiece), when the fingers go past 12 the next figure is 1, this is what is happening with your gauge the needle is slightly out of sync with the sender and is going slightly past full, this in turn is taking it to the next figure which is zero. Taking it further I have seen the opposite situation when the fuel is very low or when the engine has been switched off the needle has rested at full. I am sure it will correct itself when you have used some fuel.
Post #351900 12th Oct 2015 7:34pm
tone2711
thanks M3DPO
thanks for info DPO... i have thought ive perhaps knocked something out of kilter filling to top.
Thanks pal.. tony remaining silent when one should be protesting makes cowards of brave men.
Post #351902 12th Oct 2015 7:45pm
johnboyairey
I bet when you tell the missus' about the funny readings, and what to expect, all she will say, is....
' Did you swipe the nectar card!'
Post #351958 12th Oct 2015 10:48pm
