Home > Maintenance & Mods (L322) > starting problem sometimes
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
i have had a starting problem ,sometimes it takes a few turns to start and other times it fires straight up .fault codes 1260 and 09f6.i have changed the pump on the side of the tank and put a new filter on ,it doesnt do it all the time ,has anybody had this problem ,thanks.
Post #352030 13th Oct 2015 1:25pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I had this on my TD6 and was two failing injectors
Post #352050 13th Oct 2015 3:31pm
miggit
Does your Glow Plug light come on? and do you wait for it to go out before starting? It can make a difference to how quickly it all fires in to life Thumbs Up
Failing injectors normally make a hot engine harder to start than a cold one. Yesterday I couldn't spell Engineer... Today I are one!
Post #352056 13th Oct 2015 3:46pm
cowman
yes the glow plug light does come on ,i do wait for it to go off ,i have done a bleed off check on the injectors and they seem to be fine,it does it when cold or hot
Post #352070 13th Oct 2015 5:27pm
miggit
Possible air leak in the fuel pipes, intermittent glow plug timer? Tricky one that, it's sooooo annoying when it only does it some of the time Evil or Very Mad Might pay you to get it to a diesel specialist (Bosch Agent), they should be able to throw some light on it, otherwise you could be changing parts till the cows come home and still not sort it Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #352083 13th Oct 2015 6:20pm
miggit
OOOOOO what about the immobiliser in the key? maybe the ECU is having a hard time seeing it, hopefully someone can shed some light on it. I don't know if it knocks out the whole starter system or just the fuel, which would allow it to turn over but not start. I'm sure that I read about the transducer pick up playing up on here, but don't ask me where Embarassed Yesterday I couldn't spell Engineer... Today I are one!
Post #352085 13th Oct 2015 6:25pm
cowman
found the problem the fuel pump relay in the boot, is this just a normal 40 amp relay ,can i get one from a motor factors or does it have to be main dealer part only,also found i have 3 glow plugs out so doing that this week ,it doesnt have trouble starting on 3,thanks for all the help and advice.
Post #353945 24th Oct 2015 11:24am
It's just a standard 40A relay.... but it has quite a hard life.
I changed mine a while back, 70K miles, on a preventive basis and used a genuine one from Dan. When I opened up the old one I found the contacts to be burnt more than I would have liked.
Post #353949 24th Oct 2015 11:38am
cowman
i have opened mine and you are right the contacts are burnt,you dont have the part no do you,thanks.
Post #353953 24th Oct 2015 11:57am
No I don't have a part number for the relay unfortunately, I seemed to remember I just asked Dan for a fuel pump relay.
If you are stuck in the meantime you can always file/emery the contacts flat, they will last for a while assuming the relay still switches ok.
Post #353957 24th Oct 2015 1:09pm
miggit
FYI a lot of those relays in the boot fusebox are just standard type relays, I know that the EAS is a 70 amp one. Have a look at the numbers on the terminals and check them on google, there is a very good chance that it's a std relay and you can save a few quid, by not having a landrover sticker on it Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #353991 24th Oct 2015 10:44pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Idea for company --- making Land Rover stickers !! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #353993 24th Oct 2015 10:51pm
miggit
^^ Laughing Laughing Bow down Yesterday I couldn't spell Engineer... Today I are one!
Post #354002 24th Oct 2015 11:52pm
mjdronfield
Perhaps a daft question -how do you diagnose that ? Turn the ignition on and listen for the pump, or will it run but not ideal power as relay is dodgy, or do you have to get the old voltmeter out ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #354012 25th Oct 2015 7:37am
cowman
you can test the pump with a piece of wire with a male connector on it take the relay out and put the spade connector in the top terminal then touch it on the live red wire you can hear the pump if it is ok ,or swap relay with the next one to it to test.
Post #354029 25th Oct 2015 10:20am
