Home > Technical (L322) > Help! What is this sound? - 2003 TD6 L322
andy.cliff
New Zealand 2003 Range Rover HSE Td6 Buckingham Blue
Hey there guys. So, last night after leaving the gym, I noticed my battery light was flickering on and off.
Now, it is sitting as a solid warning light in the dash. No worries, I thought I would check the connections and just make sure that everything is as it should be.
However, when I started the Range today, I noticed there is almost like a rubbing/scratching sound coming from the engine bay (I believe)... Neutral Crying or Very sad
Is anyone aware of what this could be? Should I be parking the truck up right now?
What to do?!
See here.
Thanks guys! Kiwi lad - Range Rover TD6 L322
Murdered out crew
Dual switchback halo's
20x9.5 TSW's
More to come...
Post #352151 14th Oct 2015 12:40am
dingg1
Most likely time for a new alternator
Post #352158 14th Oct 2015 7:02am
I concur..... Pete
-Click here for Thread-
Post #352163 14th Oct 2015 7:50am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
As above.
Sounds like a bearing issue, either tensioner or component, combined with the battery light suggests it's on the alternator drive belt circuit so alternator itself. Check the belt, remove it and check the pulleys on the tensioner and alternator for smooth running. Any resistance, roughness or noise/rumble and you've found the problem.
I don't suggest you drive it unless you want to get stranded with a flat/knackered battery.
You can move it a few miles if you charge the battery up before hand but it's a risk.
Post #352234 14th Oct 2015 2:26pm
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
At least alternators are cheap for the TD6 compared to the TDV8 Thumbs Up
Post #352237 14th Oct 2015 2:49pm
Weejock
...and not water cooled like on the M62 V8 Sad
First job I did on mine, bought with the battery light on.
Post #352238 14th Oct 2015 3:14pm
